In the mid of run, i get this optimization error8111. What does it mean? It says to contact customer support.
when Inspire runs, it uses OptiStruct behind the scenes. You can take a look at the run folder.
You might get some clues on the error by looking at the .ouf file in the running folder.
when Inspire runs, it uses OptiStruct behind the scenes. You can take a look at the run folder. You might get some clues on the error by looking at the .ouf file in the running folder.
Thanks for your reply. Got clues from .out file.
