I have two meshes, an original and a deformed mesh, and I created vectors to track the displacements of several points-of interest to hopefully make a transformation matrix. These Vectors were made using the same node on the two different meshes as the start and end points. Is there anyway to export these nodes? I know I can export the nodes as coordinates and manually pair them up, but there are too many to do by hand. Is there anyway to export the vectors like elements in .inp file, with the start and end node ids?
