I have an irregular solid (Dental crown) STL file. I have imported it in hypermesh and meshed it using tetrahedron elements and have created an inp file to import in ABAQUS. In ABAQUS after carrying out the thermo-mechanical analysis I need to cut one section of the crown to see the stresses within the material. However, since I have tetrahedron elements, cutting the solid (done by elements removal) results in irregular surface in ABAQUS.
Can I define a cutting plane in HyperMesh (as a part of Step 2, following Step 1 of stress analysis) and redefine the mesh of that area? Is there any other way to tackle this issue?
Looking forward to the suggestions.
