Hi
I'm very new to flux. I tried to create a 3d model for a solenoid.
When I tried to complete an Infinity Box, I got this error message: "Failed convert object: null pointer".
How can I fix that?
I used the tutorial below
Did you checked before adding the infinite box if your geometry is correct? If it is not the case can check again the steps that you followed on the PPT file.
Which Flux version you use?
Best regards.
I got the message above. The intersections themselves are not a problem for me at least.
How can I fix them?
can you chekc if you don't have missed any step during the geomtry creation (assembly for example). Thanks.
It worked!
I had to cut all of the interactions
Thank you very much!
It worked! I had to cut all of the interactions Thank you very much!
You are welcome.
