I would like to do a parametric sweep of dielectric permittivity from 2 to 500 (no loss tangent) for a dielectric cube. In order to do that, I am using the EDITFEKO to give the required inputs and outputs. I have saved the list of permittivity values in a txt file. I would like to call this txt file and run the EDITFEKO and then save outputs. The below figure shows the piece of code from my EDITFEKO file. Unfortunately, the EDITFEKO is showing an error saying it cannot read the txt file. I also tried creating an XML file but it did not work either. I would really appreciate any help on this problem.
Thanks a lot. I have also attached txt file for reference, Alternatively, can we vary the permittivity using for loop?
--Kalyan Durbhakula
