I have a little problem with exporting local coordinate systems. I need them to postprocess welds but I don't use them in the analysis, so I must assign at least one node to the system that I have created. I do it by using this menu:
Once I have assigned the nodes to the system (with 'set displacemente' button), I export the model and I get a piece of code from the exported file like this:
*TRANSFORM, TYPE=R, NSET=HM_auto_transform_14AA0
-4.463E-08, -0.9995139, 0.03117584, -1.0 , 1.4901E-08, -9.537E-07
**HMORIENT ORIGIN 3.2 ,-1.324 ,-0.18998
I was wondering if there is a way to export a local coordinate system with a NSET previously created in HyperMesh by using TCL. I know you can do this changing the button in HyperMesh (like I show in the image below), but when I try to do this with tcl commands, HM ignores it. Furthermore, in the command file this action is not recorded.
I was trying with this:
set name [hm_getstring 'Name=' 'Please specify a name for the NSET.']
*createlistbypathpanel nodes 1 'Select nodes to create a weld'
set lista [hm_getlist nodes 1]
*clearlist nodes 1
*createentity sets name=$name ids={nodes $lista}
*createmark systems 1 'by collector id' [hm_info currentcollector systcol]
set sistema [hm_getmark systems 1]
*createmark sets 1 $name
*systemsetanalysis sets 1 $sistema
Can someone help me?
