I was wondering if there is a way to import & input pressure values on shell elements/surfaces using a tabular format in HM/HW?
I have a tapered pipe where the pressure values varies linearly along the length. Not only the values vary linearly, they also vary circumferential or angle (Theta - across the circular cross-section). Anyways, I have generated the pressure values and they are in the following format
Theta(Angle or Radians)/Distance
0 D1 D2 D3
90 x x x
180 x x x
270 x x x
360 x x x
What I want to do is create a custom cylindrical coord system and if possible use a feature in HW/HM to declare the Theta & Length (Z) as independent variables and import the above type of values and essentially create a field. Next I will apply pressure load referencing the field distribution.
The above can be done in Patran but hoping it can done in HW/HM as well because I'd prefer to do as much as possible in a single environment.
