I think I may have found another bug in HW/HM 2017.1.
Sometimes HM is not able to assign properties to elements when it is attemped via Properties containers. Right click on a property container and select assign. Chose the elements and click on proceed. No assignment takes place.
I have to assign prop via component containers i.e. right click on a component container -> assign -> Select the right property card. Then the property card is assigned to the elements.
I have to say here that in my future attempts, I was able to successfully assign property via the prop cards browser.
It seems like it is happening ONLY the first time I try to assign via the property browser. It happened yesterday when I was trying to assign PSOLID property to a solid elements and again earlier today when I was trying to assign PSHELL prop to QUAD elements.
If this can be reproduced by others, perhaps then the Dev team can take note of this as well to fix for future releases.
