Questions on FBD using H3D file
User: "Burner2k"
Altair Community Member
Updated by Burner2k
I typically work with Nastran solver and thus am more familiar with exporting solver deck to Nastran via HM/HW.
Anyways, I was just doing a test run for Optistruct and I did not touch any of the control cards section. I just created a load step and selected the SPC & load cards along with required output vectors. One of the outputs I requested is GPForce. I submitted the job to Optistruct & sure enough, the analysis ran without any issues. However, when I open the files in to HV and try to do a FBD analysis, I get an error.
Screenshot of .fem file
<?xml version="1.0" encoding="UTF-8"?>05.thumb.PNG.12b81cbb0820136422d40a5bc9fc56c3.PNG
Just clicked on 'Optistruct' button in this panel to submit the job for analysis.
<?xml version="1.0" encoding="UTF-8"?>06.thumb.PNG.530b896a79cd0b77a7c57a5a24ef3b47.PNG
Importing the model & results (?) file in to HV with Advanced Math template.
<?xml version="1.0" encoding="UTF-8"?>07.thumb.PNG.77190c4d4a7e4ff1516cd2d6ea828bed.PNG
And the error when invoking FBD option.
I could open .out file in a text editor but I was not able to see any results like element/grid based outputs like I usually see in a Nastran F06 file. Not able to make out if the solver actually considered GPForce option even though I have specified the same in HM.
I am sure the above is basic but would appreciate help.
