Linear 1D Issue
User: "Burner2k"
Altair Community Member
Updated by Burner2k
I understand that mesh should match between two sets of elements for which 1D connection is desired.
I have a scenario here in which I have selected elements for which mesh matches. But still HM shows that element order differs.
<?xml version="1.0" encoding="UTF-8"?>05.thumb.PNG.2003b23e573c13b2a2e911f4f640ba71.PNG
As shown, I am trying to generate 1D nodes just between sets of elements which have been selected (highlighted by White). I believe in this scenario, HM should create a set of 1D elements.
Also what is the alignment referring to? Same question on density. If I chose 2 as density, will there be two elements between each node of top & bottom plates?
Another picture showing mesh alignment. Alignment of elements whose edges are darkly shaded.
<?xml version="1.0" encoding="UTF-8"?>04.thumb.PNG.38775c7d20da7c05ded0d3d079ae6e6c.PNG
If I have set of surfaces which have dissimilar meshes, then I have to create individual 1D elements manually? Currently no option in HM to create automatically?
Thanks...
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    Hi
    Press F1 to know how to use that panel
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi Burner2k,
    this happens to me too sometimes, when it fails to connect.
    It helps to isolate only the elements/nodes to be connected and pick the alignment nodes away from the boundary.
    The meshes do not have to match exactly, as long as the elements are equal in type (tria, quad) and distribution (quantity in different directions). In other words, nodes can be perturbed.
    Alignment nodes can be seen as a frame of reference between meshes. You are right about density.
    User: "Burner2k"
    OP
    Updated by Burner2k
    Hi Ivan,
    Thanks for the response. I have a couple of follow up questions.
    Could you please elaborate more on the isolating the elements part? Should I create a new component for these elements? Also, as shown via pictures in my original post, I do believe, I have same type of elements (they are actually plot shell elements...no property assigned yet) and the selected bunch of top & bottom elements match exactly in distribution.
    Frame of reference for what? 1D elements? I guess, one way to learn is to try it out. https://filefox.cc/z9us5wjz2k0a/01227_Young_Girlfriend_blow_n_ride.mp4
    Tinh, the help via F1 is unfortunately not very clear on what alignment refers to.
    By isolate I mean you should only have the elements to be connected visible by using mask panel.
    Alignment nodes are used to identify congruent features on both meshes, because currently Hypermesh can not automatically recognize mesh pattern to be connected. If for example there are two identical meshes but one is rotated then you should help HM map 1D elements between by specifing some reference nodes.
    There is analogy to pattern repetition optimization in Optistruct, wherby local coordinate systems are defined for each group of elements.
    You probably should edit/delete the link ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
    User: "Burner2k"
    OP
    Updated by Burner2k
    Ivan, thanks for your support. After selecting alignment nodes, 1D elements were created.
