I have installed the latest HW 2017.2.2 Hotfix. I am working in Engineering Solutions -> Aerospace -> MSC Nastran User profile.
I have turned ON Checks Toolbars under Toolbars->Hypmersh->Checks. But each time I open HW Desktop, the checks toolbars is not visible. Gotta turn it back ON manually. Previously, I used to work on Hypermesh -> MSC Nastran User Profile with Checks Toolbars ON and I did not face the issue of disappearance.
I will clear all the Temp files along with Userprofile files in Altair directories and see if that fixes the issue.
Secondly, I am hoping some one could reproduce this. Imported a STEP geometry in to HM and it created a component automatically (lets call it 'A').
I was doing Hex Meshing in HM. Had to break down the solids in to various blocks to make it mappable and/or for easier meshing.
Used 3D -> Solid Map -> General command to 'extrude' a 2D mesh. The resulting 3D mesh would be placed in a 'Solid Map' component. Moved the 3D elements from Solid Map component in to 'A'.
I created a new Component 'B' and moved all the solid geo along with its associated 3D elements in to 'B' from 'A'.
Now, even though I had made the component 'A' active, whatever 2D elements I was creating was being placed in to the component 'B'. Each time, I had to manually move elements from B to A which was annoying. I have not faced this issue before and there fore not sure if its a bug or something which happened one-time!
Just wanted to report the above two.
