Rigid Elements Display Issue
When my model is imported in to HV, the Rigid Elements are whacked out of position. The model is rendered in Undeformed state and still the elements are not in position.
I am exporting HM file in to MSC Nastran solver deck (bdf) & the result file is being written in op2 format. Importing both bdf & op2 files in to HV for post-processing.
The above is not a big deal but definitely will be an issue if presentations are needed.
Just attaching a couple of images of how the model looks in HV vs HM. <?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>
Share your model HM?
0 -
I can share the bdf file (which has already been attached). Anyways, I did try importing the bdf file in to HM and the rigid elements are in proper place.
0 -
Yes, your Rigid elements are good. I just checked your BDF file.
So I don't know where comes from your issue.
