🎉Community Raffle - Win $25
Join and Win
Create a Spatial Field/Table in HM
User: "Burner2k"
Altair Community Member
Updated by Burner2k
I have a spatial pressure distribution which I want to import as load in to HM. I am aware of Linear Interpolation -> Using File feature but I believe the structure of the File content should be X, Y, Z, Pressure value.
In my case, I have X, Y and Pressure Value but not Z. This is how the load values came...Is there anyway I can create an elemental or nodal pressure distribution?
Not sure if this is gonna help...in MSC Patran, we used to create a Spatial Fields (essentially a tabular format) using the above and use point out to the Field during Pressure application. I want to do as much pre-processing as possible in HW/HM and hence the question.
1 - 3 of 31
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    You don't have 'Z' so you work on 2D mapping?
    Try to add a constant value as Z-coordinate to fit required format of Hypermesh?
    User: "Burner2k"
    OP
    Updated by Burner2k
    Actually, the values represent pressure distribution on upper & lower aerodynamic surfaces. The surfaces are contoured and have variation in Z.
    To be honest, I am not really sure how the above format i.e. the absence of Z coords is handled in Patran Fields, but it does give accurate pressure distribution. I will try to find out but its gonna be hard since the values were generated else where and was told that we are not privy to that info.
    User: "Piercarlo Marchegiani"
    Updated by Piercarlo Marchegiani
    Hi, where you able to solve this problem? I am having the same problem right now.
