Hi, I have a short question:
Is it possible to translate nodes automatically in the direction of a defined offset in that way, that I get a shell without offest but relocated nodes.
For example: Shell t=5mm and offset=2.5mm. (the nodes are on the outer Side of the "Element").
Result: t=5mm and offset=0 but Nodes translated to the half of the "element" / Midplane).
I know, offset is easy to use and works fine. But in my case I have to avoid the offset option.
Greetings and thanks
