Good Morning
I have a problem with a Random Analysis. My model is in meter, i want to apply a FRF of 9,81 m/^2, which unit measure should I use for PSD
g^2/Hz or (m/s^2)^2/Hz? I am confused
Thank you in advance for the answer
Maybe this knowledge base will help you.
https://community.altair.com/community?id=kb_article&sysparm_article=KB0117481
thank you Adrian, very kind from you
But I am looking for some indications where the model is in meter and not in millimeter. All the indications I found, are with the model in millimeter. Do you know someone I could I speak with directly?
thank you Adrian, very kind from you But I am looking for some indications where the model is in meter and not in millimeter. All the indications I found, are with the model in millimeter. Do you know someone I could I speak with directly?
unit load 9.81m/s2
PSD in G2/Hz
