Hi! Everytime i try to import a file from SolidWorks 2020 it says "Unable to import model file". Isn't this version supported?
Solidworks 2020 is supported in the latest version of HyperWorks : HyperWorks 2020.1.
Please find in attached the release note of this update.
You can download this version in the marketspace.
Thanks,
Richard
Usually the files generated with the latest version will not be compatible with the pervious versions/older versions (but vice versa is possible) i.e., back compatibility will not be present.
As mentioned in the above post, Altair HyperWorks Release Notes are helpful in knowing the compatibility.
Thank You!
