Hi experts!
I'm using EDEM to simulate a cutting process of grain. I imported some geometries of the cutting drum. There is guiding plate for the generated particles, a geometry to represent the cutting knife and a cutting rotor to pull the grain over the blade.
I don't know how to set the simulation parameters correctly for cutting particles. Shall I select INTERACTION: particle to geometry combined to which base model?
Thanks for your help.
Greetings,
Philipp
