i have die assembly and import it to "inspire Extrude polymer 2022" . i do the instruction as the tutorial but in my case program dose'nt solve the problem . can anyone help me? (files attached)
Hello @amir shah ,
The model you have attached is not correct. It does have the die geometry which is needed for extruded hollow shapes as you have in Profile. Adding some circular sections will not help extrude such complex hollow shapes.
Thank you and best regards,
Narendra Singh
Altair | Nasdaq: ALTR
Connect with us: LinkedIn | Twitter | Facebook
#OnlyForward
