How multi-floor buildings can be created in WallMan?
The generation of multi-floor buildings in WallMan can be done by importing the *.idb file of a single floor on another height via File>Import>WinProp Binary database into the loaded *.idb single floor database (please note to select the option “use material properties from existing file” at the selection window as otherwise the materials will be duplicated.
For the change of the display height in the (x/y) view please use the “3 rd” button from the upper tool bar, here you can change the height at which the building is intersected for display.
