I have hex elements as shown
after meshing instead of 2 columns , i have a requirement of 3 columns then using SPLIT option under 3D page i did split in given node direction(red line)
i have 3 columns now ,but the average length is not adjusted (bigger and smaller length elements)
Question: how to adjust its average length of elements allover thickness
like this
is this possible in hm
apart from remapping with given number of layers
Satya,
I'm guessing your actual model has more going on, but for what you show, it seems you could just distribute temp nodes and use the move tool to pop the layers into position.
