Hii all,
I want to perform Axisymmetric analysis on 3d flange body.So while performing the analysis I am getting different results for both half and cyclic model case.I used solid map to create 3D elements.I am also getting different numbers of nodes and elements for both the cases after meshing,if that is the issue.
Therefore,please guide me onto this that how can I perform the analysis to get the same results.(PS:I have to create 3D elements only)
