I get an error while trying to open RADIOSS animation files from in hyperview. Graphics card is up to date, but I am not sure where the problem is.
Could you share result file to check same at our end?Please let us know the version of SE.HyperWorks Student edition 2017.0 comes with limitation of 100000 nodes limitation.
Hi Rahul, I have sent you too files which give same error. I am currently using SE 14 and also tried with 2017, but they both give same error.
Please use h3d file for Radioss solver for postprocessing.I don't see any h3d file in your shared files.
I generally do it by importing only the Animation files into Hyperview at my work place and it works fine. Could you please tell, what's the reason to use h3d file in student edition?
H3d is the binary result file. I just checked shared A001 file in full version which loads without any warning & it has 4 lakh + elements(seat frame assembly).So if you have loaded h3d file in Student edition,it would have given you the reason for exact error. As said in my first reply of this post ,student edition comes with 100000 nodes limitation.
How can i reduce the nodes? I've the same situation of >100,000 nodes in my student version
Thanks,
Regards
