Hi Walid,
The curve shown is the induction against time. Do you want to plot it against time or against spatial position?. Also is this the induction on single location or maximum on a region?
For plotting against time, the best way is to create a sensor from the toolbar or from advanced menu (either of point type or operation type depends on what you want). After create the sensor you need to evaluate it. Then you can plot the sensor value by creating a curve against time.
Thanks,
Thank you very much Muhamed
