I am trying to calculate the max speed of the machine using (find max speed) the simulation simulates to calculate the min speed and the max speed after interrupting and showing me this problem.
Hi Walid,
the error message in French seems to say there might be spaces in one of the formulas. I am guessing the macro is using the name of an entity without removing the comment. Please check all the coils name and comments. remove any comments if there are some and try again. It could be on the coils regions or components, or maybe on other things like the mechanical set or instance.
Best regards
Thank you for your reply.
I have deleted all the comments for the settings.It displays this error
