Hi Walid,
The periodicity in the Flux project can be created using the menu Geometry -> Periodicity -> New
At this steps you will be able to create a Even or a odd periodicity depending on the number of poles represented in the Finite Element domain (Odd if 1 pole is represented or Even if 2 poles are represented)
Before to create the periodicty you have to check also that the winding respect the periodicity in the FE domain you represent.
I suggest you to have a look at the tutorial Brushless IPM motor (embedded magnets). A 4 pairs poles machine is represented with a odd periodicity.
You can launch the Flux project from the supervisor you will be able to see how the periodicty is defined.
I hope this helps .
Best regards.
Cyril Favre
Hi Walid, The periodicity in the Flux project can be created using the menu Geometry -> Periodicity -> New At this steps you will be able to create a Even or a odd periodicity depending on the number of poles represented in the Finite Element domain (Odd if 1 pole is represented or Even if 2 poles are represented) Before to create the periodicty you have to check also that the winding respect the periodicity in the FE domain you represent. I suggest you to have a look at the tutorial Brushless IPM motor (embedded magnets). A 4 pairs poles machine is represented with a odd periodicity. You can launch the Flux project from the supervisor you will be able to see how the periodicty is defined. I hope this helps . Best regards. Cyril Favre
thanks you
