I want to use OptiStruct to optimize thickness of an aluminium component made of PSHELL elements by using free-size (it is not a composite). I want to minimize the mass and constrained it to material failure (yield and ultimate stresses for compression, tension and shear).
Where should I add these material failure data? Should they be specified in the material section or in the optimization constraint for stress response?
Thank you in advance
