Hi everyone. Every time I try to use the draping estimator a message pops up: 'Invalid template! Please check!' I don't know where the problem migth be. Thank you !
Please find the below link for your reference to drape estimator. Cross check the steps which you are following and do get back if the issue persists.
Link: https://altairuniversity.com/learning-library/drape-estimator/
Thank you
Hi;
When I wrote the first time I had already followed those steps. I dont know if the drape estimator requires certain geometries. I have not found yet the problem.
Thank you for the response
This is the message. I tried to do the same geometry of the video and still doesnt work.
