is it possible to get the local Stiffness Matrix of each element?
I need this matrix in an optimization step.
Thank you
Alex
I see some posts about output k matrix of full model only
Can you calculate element k matrix from it shape and properties?
I want to avoid that.
But if there is no other way I could do this.
I would like to extract the local stiffness elements as well to compare my FE implementation to Optistructs. Is there a method to do this?
Thanks,
-Eric
