Hi i want to use an additional coord system to interrogate displacements results. When the new coord is applied and the pick info used with this new coord system the results don't seem to be aligned to the chosen coord system
in the pic attached the picked values are interrogated based on coord system 2 which has Y & Z on the face and X into the component. This should result in output displacements with X value = zero as the face chosen is in the Y-Z plane ( x=0) but none of the picked values show zero!
can you confirm what the Displacement results shown in the pick info window relate to?
