 I have modeled a wideband microstrip patch antenna in FEKO. I want to use HyperStudy to find one optimum value of a design parameter that yields the best bandwidth (i.e., best S11 value over the entire frequency range, say 1 to 3 GHz). I shall be glad if you could please let me know the procedure.
 Thanks in advance.
 -Bidisha
 P.S. So far, I have used HyperStudy to find the optimum value of a design parameter to obtain the best S11-value at a single frequency point. I tried using the multi-objective optimization feature (by defining S11 at 31 frequency points manually - please find the attached image) for my current objective of bandwidth optimization, but it resulted in 31 different optimum values of the single design parameter at the 31 different frequency points.
