I want to predict the S11 parameter of an antenna using HyperStudy. The general workflow is to import the initial data from FEKO, and then use HyperStudy to create N training samples using one of its many in-built algorithms (where N is specified by the user).
Instead of this, I want to use my own training samples, that I had generated earlier using FEKO. Can I do that?
Thanks in advance for your response.
-Bidisha.
