Is there a way to construct non-canonical solid structures using FEKO (other than Cuboid, Flare, Cylindrical, etc.)?
-Bidisha
Not sure if this is exactly what you need:
You can construct curves, e.g. using the Analytical Curve (curve using an equation) or Fitted Spline. Then you can sweep or spin them to make a surface or solid. Or you can try the NURBS surface and with a sweep make again a solid.
Attached a cfx.
