Hi;
I want to bring into a single SPC other four existing SPCs .it's possible ?
Hi
press Shift+F11 change 'elems' to 'loads' and move your spcs to target collector
Your request is not clear. Do you want to create a MPC? or create a way to 'collect' 4 different SPCs?
Do you want to bring all four SPCs into one single load collector?
if that is case, please move/organize as Tinh suggested.
Goto Organize panel (SHift+F11 or Tools page>> Organize) select SPC and destination load collector, Click Move.
Also see
OptiStruct > Reference Guide > Input Data > Bulk Data Section:
SPCADD in help
Bulk Data Entry
SPCADD – Single-Point Constraint Set Combination
Defines a single-point constraint set as a union of single-point constraint sets defined via SPC or SPC1 entries.
Prakash Pagadala its that what i mean
