I am using OPTFEKO, and I want to know if there is a way I can obtain the total memory consumed and the total run time? (Note: I have the individual .out files for each OPTFEKO iteration).
Total optimization time is not available directly. The simplest way would be to multiply the no. of iterations with the time for a single iteration (there might be a small difference in the run-time for each iteration but they all should have very similar timings).
