How can i delete an Hole in a 3D solid ? ( in 2d we use pinhole but i don't know how delete it in 3D )
HI Oggy,
There are several ways to do this in HyperMesh
1) Delete the solids. Now we are left only with surfaces 2) Remove the bounding wall of the holes to get free edges so that we can use defeature panel 3) Remove the pinholes and recreate your solid.
OR
User was asked to go to Geom-->Autocleanup-->Edit Parameters-->Parameters file editor Dialog box opens-->Check the solid hole recognition and give the required Radius-->Select Autocleanup.
This would remove the holes within the given radius.
http://www.altairuniversity.com/wp-content/uploads/2013/11/Remove-holes-dimensionTTF.pdf
