Hi all,
i want to lear howa to do some forming analysis with hyperform, i'm looking for tutoriels that can help,
Thanks a lot,
Hello Sir,
Check out Altair help
Find HF-1000 For One step analysis
HF-3001 for Auto process in incremental RADIOSS
Hello Sir, Check out Altair help Find HF-1000 For One step analysis HF-3001 for Auto process in incremental RADIOSS
Thanks a lot sir,
i have a question plz, what this the difference betwen one step analysis & incremental ?
Basic Diff is that, in one step you can solve the forming analysis using blank surface only, while in incremental analysis we can use different punch, die, binder - setup with blank.
One-step analysis gives tentative results while incremental analysis gives most accurate results.
There are many differences other that this between these modules.
Thanks a lot
