Hi to All,
Recently, I saw a paper which uses modal analysis of unit cell ("Characteristic Modal Decomposition of Reflection Phase of a Microstrip Patch Reflectarray Unit Cell, Abdul Maalik, Roberto G. Rojas, Robert J. Burkholder").
In the paper, it is written that he FEKO MoM solver is used to compute the first five characteristic
modes of the infinite array.
In Feko, defining a structure with periodic boundaries and CMA are not defined together.
I think that they extracted Zmn of periodic structure and used its characteristic modes in the paper.
I have some questions about this paper if you could answer them I would be appreciated.
- I could not find about the periodicity length of the infinite array in Feko.
Is there a constant value about the block size or is it adjustable or does it depend on the electrical size of the structure?
I need this information to extract Zmn if possible.
- Could we use the characteristic currents calculated in Matlab extracted from Fekos Zmn again in Feko
to calculate calculate near fields, far fields and reflection phase in FEKO with these imported characteristic current?
In the paper, they say that they computed the reflection phase of the structure.
Can I extract the impedance matrix then import the characteristic current into Feko to calculate reflection phase, near fields or far fields, etc.
Best regards
SO
