I have modeled a 10x10 array of microstrip patch antennas. I want to use the MLFMM solver to check the radiation pattern of this array. In order to do that, I first selected the 'Solve Model with multilevel fast multipole method (MLFMM)' option under the MLFMM/ACA tab of the Solver Setting. This resulted in error 37356, which says that DGFM and MLFMM cannot be used together. Therefore, I disabled the DGFM solver and then checked the MLFMM solver only. Now I am getting error 2580, which says that 'No special Green's function may be activated with the MLFMM'.
Where am I going wrong? Please let me know the correct way to use this solver.
Thanks in advance.
