Dear Sir/Madam,
I am running the exampled provided by Altair: Virtual Drive Test. I started running RUNPRO. However, RUNMS is disabled as seen in the screenshot. Could you please assist me in running RUNMS?
Thank you
Dear Hussain,
To execute RUNMS, please look at the following steps.
1) Project > Edit Project Parameter > Propagation Tab > Check "Consider Antenna of MS"
2) Please click on "Edit Parameters" and set up the following window.
(Afterwards, this window is opened also by "Project > Edit Parameter of Mobile Station".)
Best regards,
Jaehoon
