How much time required to complete one analysis because I am waiting from 3 hours but analysis is still in process.
If you didn't see a message from Inspire saying that the problem will run more that XX minutes, you don't have other jobs running or have low memory available, then the job probably crashed and I suggest you look in the directory where the files are located (look in your preferences for this) and review your log and out files for information on what might have happened (errors). It could be issues with bad geometry that was imported in but the these files will give more information.
