I'm using Hyperstudy 2017.2 and Radioss as a solver. I encounter an error when I perform the evaluate step in the DOE approach. It happens that during a run (whatever) the evaluate and extract steps can't finish succesfully, but there aren't errors in the messages box and in the .out file I can read that analysis is already finished with normal termination: in spite of this, the cursor keeps turning and seems to be waiting to finish evaluation. I realized that when it happens, there isn't the .h3d file in the run folder, even if run is completed and all animation A0# are created. I realized also that by finishing the 'hvtrans' process from the task manager, or (is the same) Tclsh85t application, hyperstudy concludes the evaluate step, extracts results and goes to the next run. It's a random problem, but it always happens at least once.
Thank you all for helping out.
