Hello to everyone,
I would like to know how the program is calculating the RSS values on Prediction Planes (last column):
Guessing that the receivers behave in a linear way, in every measuring point, the amplitude and the phase contribution (which is a complex number) of every ray path (using SRT) obtained in the output logs of the transmission matrix should be summed up. Then we can calculate the modulus of the resulting complex number and 10log(abs(result)) for determining the RSS in dbm (maybe I am wrong). Would this be correct? I need to get the RSS values in this way instead of using the output log of the above image because I am trying to combine the results of two transmitters into every measuring point, so the only way to do it is by combining all the measurements in every specific point.
Basically, I want to have in the same result file, the contribution of both transmitters instead of one file per transmitter.
