Hi all,
I am using the WinProp API. When I output the Rays.str file in a SRT simulation I cannot get the transmission matrix values as provided by the GUI. Could anyone tell me if I am missing any parameter in the API?
This is what I get with the GUI:
This is what I get with the API:
I would like to have the transmission matrix values as well.
please have a look on the attached WinProp API document which is included in the 2019.2 installation.
If WinProp_Predict(see page 35) is called with DataRaysOut structure the ray properties are also computed and returned in the structure WinProp_Ray (see page 224). This includes the complex fieldstrength vectors, however not yet the transmission matrix. This means so far the transmission matrix cannot be written in the .str file via the WinProp API, but you might use the complex fieldstrength vectors instead.
