Hello All,
I am looking for python code to automatically invoke Simlab and run the FE modeling script .
Thank you
If you go to SimLab help, you will find the options for 'batch' execution.
Hi Adriano,
Thank you for the reply..
I have learned new thing with this..
But I am looking for invoking SimLab using compose and running my FE modeling process
I have some manual work in between so using compose I can run my scripts step by step.
Kindly help me with a code can be used to invoke SimLab from compose and executing the remaining script.
Hi Adriano, Thank you for the reply.. I have learned new thing with this.. But I am looking for invoking SimLab using compose and running my FE modeling process I have some manual work in between so using compose I can run my scripts step by step. Kindly help me with a code can be used to invoke SimLab from compose and executing the remaining script. Thank you
you can simply use 'dos' command in compose to call the command window and execute command lines just like in windwos 'cmd'
if you want to use python command, then
https://datatofish.com/command-prompt-python/
You can watch the 90-minute conference presentation below.
https://www.altair.com/resource/using-altair-compose-calculations-scripts-to-improve-accelerate-cae-processes-playlist
