Failed to load .Log file
User: "Rodrigo Martín"
Altair Community Member
Updated by Rodrigo Martín
Hi, I am an aerospace student trying to use Hyperworks CFD for my end of degree paper.
I have been following some tutorials to start getting familiar with the software. I followed first the exhaust manifold tutorial you guys have online, and everything is good (run manager says the calculations were correct) until I attempt to open the results file (.Log file) to see the results, where the program failes to load it.
I have also tried to right click the "View results" button in the run manager tab, after which the program crashes. I have also tried other simple geometries like a sphere, still the same happens.
After a couple days trying every solution I find online, I am quite desperate and considering to try other softwares.
I have the student license, and have installed the "Hyperworks Bundle" and the "CFD solvers" from the email. I attached the manifold .log file and the .hm file just in case it is of any help.
Thank you in advance.
1 - 1 of 11
    User: "acupro"
    Updated by acupro
    Try using the Convert Tool to generate the Ensight format file.  Will that (.case) then read into Post?
