with different load condition i often get a non-continuous shape with material interruption . Is there a way , an options to get a continue shape? I insert an image as an example of the non-continuous shape that I get.
have you changed the slider bar in here?
Sometimes increasing it a little bit, helps.
Additionally, I'd try a few different settings for 'thickness constraints' to help as well, avoiding too small structures.
