i am facing issue while running dynamic analysis on motionview.
Hi Aadi,
Does that error message prevent you from exiting the menu? I would try to Clear the message and Finish the definition as it may have only come up while you were entering in the values.
Hope this helps!
Adam Reid
Curious, which MotionView version are you using? Which Vehicle library are you using (car/small truck or Heavy Truck)?
Best,
Christopher Fadanelli
