If you mean convert floating point to integer, then yes, convert block set to integer result will do it.
Hi Nitin,
It is possible with the convert block . May I know what is purpose here you are trying to achieve??
If you could attach your embed diagram(.vsm file) which you are facing the difficulty with it could be easier to resolve the problem .
