I was wondering is there a more efficient way to simulate an insulated antenna in FEKO, a media wire coated with dielectric sheath as shown in the figure below.
Currently, I perform the simulation by creating a dielectric cylinder and metal wire geometry and meshing them with triangles and segments. But it produces so many triangles, and the efficiency is quite low.
Can I use the cable modeling features in FEKO to do the same thing?
Thank you.
