Dear guys
Where can I find/download the coupling code/dll for edem 2022 -fluent and also the corresponding coupling manual? Many thanks.
Best wishes
Sunny
You'll need to be logged into Altair Community but you can get the coupling from here:
https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0116549
I haven't updated the coupling compilation tool since EDEM/Fluent 2021 but the coupling should still work with EDEM 2022 if you select EDEM 2021 and change the path to be EDEM 2022.
Let me know if that works.
Cheers,
Richard
Hi, You'll need to be logged into Altair Community but you can get the coupling from here: https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0116549 I haven't updated the coupling compilation tool since EDEM/Fluent 2021 but the coupling should still work with EDEM 2022 if you select EDEM 2021 and change the path to be EDEM 2022. Let me know if that works. Cheers, Richard
Hi Richard
Many thanks for your quick reply. I have tested it. Yes, it works for EDEM 2022 and Fluent 2021.
But one question, it does not work well for fluent 2022, as DPM model in fluent 2022 seems to have a big change, thus, during Windows_GUI_compilation, it said variables not enough.
Hi Richard Many thanks for your quick reply. I have tested it. Yes, it works for EDEM 2022 and Fluent 2021. But one question, it does not work well for fluent 2022, as DPM model in fluent 2022 seems to have a big change, thus, during Windows_GUI_compilation, it said variables not enough. Best wishes Sunny
I had a hunch it might not work with Fluent 2022. I can take a look to see if there's anything I can do here but my guess is it might require Ansys to do the updates for that.
I can't give a timeline on when that might be updated so for now I'd say EDEM 2022 / Fluent 2021 is the most recent you can use with that version of the coupling.
